Simplify3D - gaps in floor corners
Gaps in Floor Corners
When building a 3D printed part, each layer relies on the foundation from the layer below. However, the amount of plastic that is used for the print is also a concern, so a balance must be achieved between the strength of the foundation and the amount of plastic that is used. If the foundation is not strong enough, you will start to see holes and gaps between the layers. This is typically most obvious in the corners, where the size of the part is changing (for example, if you were printing a 20mm cube on top of a 40mm cube). When you transition to the smaller size, you need to make sure that you have a sufficient foundation to support the sidewalls of the 20mm cube. There are several typical causes for these weak foundations. We will discuss each one below and present the settings that can be used in Simplify3D to improve the print.
Common Solutions
Not enough perimeters
Adding more outline perimeters to your part will greatly improve the strength of the foundation. Because the interior of your part is typically partially hollow, the thickness of the perimeter walls has a significant effect. To adjust this setting, click “Edit Process Settings” and click on the Layer tab. For example, if you were previously printing with two perimeters, try the same print with four perimeters to see if the gaps disappear.
Not enough top solid layers
Another common cause for a weak foundation is not having enough solid layers for the top surfaces of your print. A thin ceiling will not be able to adequately support the structures that are printed on top of them. This setting can be adjusted by clicking “Edit Process Settings” and selecting the Layer tab. If you were previously using only two top solid layers, try the same print with four top solid layers to see if the foundation is improved.
Infill percentage is too low
The final setting you should check is the infill percentage used for your print, illustrated by a slider under the Process Settings or found under the Infill tab. The top solid layers will be built on top of the infill, so it is important that there is enough infill to support these layers. For example, if you were previously using a infill percentage of 20%, try increasing that value to 40% to see if the print quality improves.
Related Topics
Version 5.1
Compatibility
Is Your 3D Printer Compatible? Enter your printer name to check compatibility with the latest version of Simplify3D. My printer is custom built or not commercially available Hooray! Your [[printerName]] is supported! When you open Simplify3D for the first time, you’ll be prompted to select your printer from a drop-down list. This will automatically apply [...]
Simplify3D Version 4.1.0
Simplify3D® Version 4.1The latest release of Simplify3D's professional 3D printing software continues to drive innovation in the Additive Manufacturing industry. Version 4.1 provides more control over the printing process and unlocks new capabilities for the latest generation of 3D printers. Keep reading to learn more about these new features! Simplify3D® Version 4.1The latest release of Simplify3D's professional [...]
V4 Software Features
The last 3D printing software you’ll ever need! Simplify3D includes everything you need to work with your 3D printer. Model setup and plating, slicing and print file creation, pre-print simulations, customizable support structures, mesh analysis and repair, machine control and monitoring, and much more! With support for hundreds of 3D printers, Simplify3D is the last [...]
Simplify3D Software
Home
Improve your print quality withpowerful 3D printing softwareExpand your 3D printer's capabilities for amazing resultsPURCHASESEE FEATURES Improve your print quality withpowerful 3D printing softwareExpand your 3D printer's capabilities for amazing resultsPurchaseSee Features The World Fights COVID-19 with 3D Printing Blog Series  Read More THE EXPERTS AGREE: SOFTWARE MATTERS 3D printing slicing software controls every aspect [...]
Education
SIMPLIFY3D FOR EDUCATORS Schools, universities, and makerspaces around the world use Simplify3D to enhance their 3D printing curriculum. Learn more about how Simplify3D Software helps you and your students master 3D printing technology. One Software Does It All 3D printers come with many different software options, which can be confusing for students. Simplify3D provides everything you [...]
Careers
Join the team!Join the team!Join the team!Build the Future of 3D PrintingBuild the Future of 3D PrintingBuild the Future of 3D Printing Competitive Benefits Work with cutting-edge tech Simplify3D is the leading global provider of commercial 3D printing software. As part of our team, you will work with the newest technologies while developing your skills. [...]
Resellers
BECOME A SIMPLIFY3D RESELLER Simplify3D Software is looking for original equipment manufacturers and large online retailers who are passionate about improving the 3D printing experience for their customers. Read more about the Simplify3D Reseller Program below and complete your application today! Already a Simplify3D reseller? Login to your Simplify3D account Benefits of Being a Simplify3D Reseller [...]
Contact Us
Have a Question? Please select from the options below so that we can connect you with the right department…
